pelelo
Geotechnical
- Aug 10, 2009
- 359
Please let me know your thoughts about this:
I am working project which consist on placing a new culvert. The soils under the proposed culvert, in some areas are organic silts. As part of the recommendations, it was proposed to remove the organic soils and backfill with SP material and them place the culvert. The thickness of the backfill is 4 feet.
The contractor, instead proposed, to place just 2 feet of SP material, and on top, to place telephone poles and then after the culvert. The telephone poles are supposed to act as foundation materials.
The poles will be wood material and will be underwater througout the life of the culvert. The poles will be placed across the excavation, 2 feet on centers.
Assuming the poles are in good conditions, would you approve this change by the contractor?. see a sketch attached.
