I have a situation in which i totally rely on the tension capacity of some a325 bolts. and the failure of the connection would be fatal. does anyone see it is a problem to weld the nut and bolts to the steel plates. although the bolts would be tightened to full pretensin force, as time goes by i worry about it will get loose especially if we get some kind of dynamic loads. thanks.
