dgidwani
- Jan 9, 2003
- 13
For a highway bridge pier supporting simple spans on either side, should the pier be designed for one HS20 truck per lane (positioned right above the pier for maximum total reaction), or for the sum of the maximum reactions from the spans on two sides?
The latter implies two trucks being considered simultaneously, and AASHTO seems to require only one HS20 truck per lane on highway bridges. What is the generally accepted procedure, and what is the correct code interpretation?
Thanks for your help,
DG
DG
