darkstorm
- Aug 3, 2007
- 4
Here is a wierd one.
I have a AB contact relay with a 5.4 tp 27 A overload driving a 15HP motor drawing 9-10amps in both directions.
Overload set at 17A motor FLA 23.
Coil voltage is 120VAC
23A 15hp 3ph contactor
This contactor works fine for 2 mos and then the coil burns up and contactor is burned shut.
The duty cycle on this is not exceeded, not even close.
Amp draw-ok
Meger Motor-good
Change contactor and Overload- several times
Check for erratic chatter and arching, -none
Check for heat after over running the contactor- no heat
I have another setup-identical- giving no problems.
Can anyone shed some light as to why this could potentially be happening.
thanks
Amp draw-ok
Meger Motor-good
thanks
