Dear all,
I'm trying to add a time dependant heat flux load onto a surface using heat flux data(point data) that I obtained from a fire simulation in Fire Dynamic Simulator. I feel that I should be using the mapped field option to apply the heat flux distribution. But my problem is when we defining the mapped field we can only use a single amplitude function. But it varys in the plane from point to point. So is there a way to incorporate multiple amplitudes when we are using a mapped field? Or is there any other way we can directly feed a time dependant point data file?
I highly appreciate if you can assist me
Thanks in advance.
Thanks in advance.
