On a high speed, well balanced rotor, when running up in speed, there is a speed where vibrations start to increase significantly. At this point, increasing the power does not increase rpm very much, but does increase vibration. After considerable increase in power and subsequent slight increase in speed, the vibration in the system suddenly drops to a level about the level before the vibration increase started. There are several resonances involved within the speed range with the increase of vibration. During the high vibration band, and only during that band, a sub-order resonance that can be explained is apparent, but also a second sub-order resonance that is not explained appears. The rotor is supported by two ball bearings, one is rigid, and one is floating in all directions. An axial mode is probably at play here as well as possible excitation of a structure resonance excited by bearing cage frequency. I have seen data similar to this before, and I do not expect simple unbalance to be the full explanation here. Is this a well known phenomena? What Google search terms would lead to info on this?
Thanks.JH
Thanks.JH
