Eng8492
- Feb 25, 2013
- 27
I am using an emergency stop controller. When the emergency stop control is triggered, the output from the control should open a 2 pole contactor carrying split-phase 240VAC and a 3 pole contactor carrying 3ph power. Because I cannot find an e-stop control with any pilot duty ratings (ie UL508 Axx, Bxx, Cxx) which guarantees it can drive the contactors directly, I was planning on using pilot duty relays in between the controller and the contactors. Is there any problem with this approach?--safety requirements are minimal-- ie IEC Sil Level 0). Basically the customer just wants a visible E-stop function.
