I am looking for some guidelines on how much heat leak is deemed reasonable for a -20°C glycol distribution system via the piping network. The piping network is mainly indoors and ranges from 4" sch. 40 pipe to 1" sch. 40 pipe (carbon steel) and will have 2" of either PIR or cellular glass type insulation. For the sake of running these lines in a congested area of the plant, I'm trying to determine if going to 1.5" or 1" of insulation would pose an unacceptable amount of heat gain.
I can show I will operate above the area dewpoint temperature with relatviely little insulation so I don't think that's a limiting case.
