Process879
Chemical
- May 21, 2008
- 10
- 0
- 0
Dear all,
can any onr tell me that the accumualtion pressure considered for thermal expansion case.
My case is , there is heat exchanger shell side hydrocarbon and tube side cooling water. i wanted to have thermal expansino valve on tube side. my exhanger is designed for blocked outlet condition 10/13 rule is applied. so i have set the PSV at tube side design pressure 10 kg/cm2(g) . my query is what shoul be the maximum accumualation pressure to considered.
