Acid-proof cement mortar
strudawg
6
Hello all,
I'm a structural engineer working on a remediation project. The original plans show steel tanks lined with a "Duro-San" membrane and then faced with two vertical courses of acid proof brick. The tanks were used for cleaning equipment and parts. The brick mortar is listed as "Lecite" cement and the adhesive used to fix the brick to the membrane and the membrane to the steel tank is listed as "Brimsto" cement.
Does anyone have any knowledge of those products listed in quotes above. Any info would be appreciated.
Thanks.
