suresh070379
When working in the main window in assembly design work bench, if type any command that will directly activate the command line window.
But, if we open any ‘sub-tree’ or ‘other selections’ window and type command, command line window is not activated.
To give the command, first we need to click in main window by mouse and then we should type.
Due to this problem, I unable to use user alias while in sub tree and only able to use accelerator keys.
Is there any option available to directly type command while in sub tree or other selection window.
Suresh
Suresh
