I have a question about stainless steel and galvanic corrosion.
Most galvanic series lists show two different values for stainless steel. One for the active metal and one for the metal after it has been passivated.
I understand that passivation will increase galvanic compatibility with more noble metals. This stands to reason as the passivated layer provides a buffer between the two raw metals as well as having removed various possible contaminants from the surface.
My question is does passivation stainless steel actually increase corrosion in a less noble metal?
i.e. Which will corrode faster 1010 steel coupled to active 410 or 1010 steel coupled to passivated 410.
My intuition is that the passivation can only help and the charts are simply reflecting the improved compatibility with more noble metals. I would be very grateful if someone more knowledgeable could shed some light on this issue for me.
Cheers!
Cheers!
