I have spent a lot of time looking for appropriate adapters to get from 1/2" BSP female connector on the end of a hand pump to M33x2 male on the top-up valve of a ground source heat pump manifold. I am dazed and confused by a world of options, no combination of which appear to do the job. Can anyone versed in the world of hydraulics please help me with a solution that will allow me to use the pump I have to top up my GSHP fluid? The solution need only withstand 1.5 PSI. I am willing to remove the existing 1/2" BSP female connector on the end of the pump's hose and replace it with something metric but the metric thing I replace it with has to fit on the existing hose that the 1/2" BSP connector is currently attached to.
Many thanks in advance
roman
roman
