Dear eng-tippers,
When adding new roof top units to an existing roof, what analysis/design methodology do you follow?
I understand that the general consensus would be to check if the stress increase is 5% or less as per the IBC, and if so, no member evaluation/strengthening would be required. Should the applied stress increase by more than 5%, member evaluation/strengthening would be required.
However, I am following the Canadian code and I cannot seem to find a similar allowance or relaxation. My strict interpretation of the Canadian code is that ANY increase, however small, requires a full evaluation. This seems rather impractical and unreasonable, especially if one is required to evaluate an existing building’s lateral load resisting system.
Any help or suggestions would be appreciated. Thank you.
