Affinity law on open type impeller 1
Wkcoo
36
Does affinity law for pump hold equally well for open type and semi open type impeller (compared to enclosed type, which gives quite accurate prediction)?
Normally yes, provided impeller / volute / wear plate clearance is correct.
Bear in mind, even for enclosed impellers, trimming dia. is a prediction only - if an exact Q or H is required it is best to trim less and then check performance, if over performance trim a little more.
As a practical matter I don't know much about the limitations of the affinity laws.
As a theoretical matter, the affinity laws can be derived from dimensional analysis under the assumption of turbulent flow. I would think that applies in most cases except when flow through tight clearances (like recirculation thru wear rings and other tight clearances) is significant (this type of flow includes a lot of friction forces which violate the turbulent assumption)
Start with a general functional relationship: DP = f {Q, rho, D, N, visc, L1/L2, L1/L3 etc}
Choose rho, D, N as our “base” variables which will be used to non-dimensionalize the other variables:
[ul]
[li]D: m:[/li]
[li]N: 1/sec[/li]
[li]rho: kg/m^3[/li]
[/ul]
Manipulate DP on LHS to a dimensionless ratio of base variables
[ul]
[li]DP: (kg*m/sec^2)/m^2 = kg/(m*sec^2)[/li]
[li]DP/rho = m^2/sec^2 (same as g*H, but g is a physical constant which doesn't belong in dimensional analysis)[/li]
[li]DP/(rho*N^2*D^2)… unitless. This will be the dependent variable on LHS of the dimensionless equation.[/li]
[/ul]
Manipulate Q on RHS to a dimensionless ratio of base variables:
[ul]
[li]Q : m^3/sec[/li]
[li]Q/(D^3*N): unitless[/li]
[li]Q/(D^3*N) will be the indep variable on the RHS of the dimensionless equation[/li]
[/ul]
Two more assumptions:
[ul]
[li]Assumption 1 - Compare only geometrically similar pump designs so L1/L2, L1/L3 are constant (and of course dimensionless) => these can dimensionless constants can be dropped from the RHS as independent variables (they will be absorbed into the function definition).[/li]
[li]Assumption 2 - Assume turblent flow. The viscosity term would end up non-dimensionalizing to something like a Reynold’s number which will be a constant friction factor IF highly turbulent flow. As long as we have only turbulent with inertia forces much larger than viscuous forces, then we can neglect viscous forces and drop viscosity from the RHS as a variable (the dimensionless constant friction factor will be absorbed into the function definition)[/li]
[/ul]
Under these last two assumptions (similarity and turbulent flow), we can write the following functional relationship:
DP/(rho*N^2*D^2) = f{ Q/(D^3*N) }
which gives rise to the affinity laws
[ul]
[li]DP/rho~N^2, Q~N, and for constant rho Fluid power = DP*Q ~ N^3[/li]
[li]DP/rho~D^2, Q~D^3[/li]
[/ul]
(2B)+(2B)' ?
To apply affinity laws to a series of pump models you need to compare apple to apple, in the sense that the models must be geometrically similar. So to be accurate you must compare one closed impeller model with another closed impeller model only, not with open impeller model as strictly speaking they are geometrically dissimilar. Similarly for open impeller models. The cross comparison may bring inaccuracies.
Engineers, think what we have done to the environment !
goutam freelance.
The OP was asking about the validity of affinity laws being applied to open or semi open impellers with the inference being are they as accurate as the results for closed impellers.
Yes they are.
electricpete:
Interesting discussion to arrive at:
1. Q varies at the ratio of diameter / speed
2. H varies as the ratio^2 of diameter / speed
3. P varies as the ratio^3 of diameter / speed.
With reasonable accuracy for minor changes in diameter /speed, for major changes of dia. or speed, the manufacturer should be consulted.
Read it as Dia. change or speed change.
Sure if you want to change speed and diameter at the same time, but in 40+ years, it's never been a requirement.
