Affinity law question 1
oodly
Back to basics here, I've got a pump on a VFD running at 60 Hz. It's moving 550 gpm with 90 ft. of head. If I slow this pump down until it moves only half the water, or 275 gpm, what will its head be? Thanks.
Or
Pump affinity for centrifugal pumps with no change in pump diameter
Flow prop to speed
head prop speed^2
power prop ^3
So half the speed, a quarter of the head so 90/4 = 22.5 ft
whether this works or not will depend clearly on your static head and system curve.
If it's not moving any (or less) water at half the speed the head will be higher up the curve....
That totally depends on what the system curve looks like. How much of your head is static vs dynamic (friction)?
The only real answer is, the head will be whatever is needed to supply 275 gpm.
TBF All the OP is asking for was what does the pump produce.
