mfgenggear
Aerospace
- Jan 23, 2008
- 3,411
Please Consensus on this matter
Customer Engineering Drawing
Gear Tab Block
Gear Data Specifies
AGMA Q8
# Teeth
Diametral Pitch
Pressure Angle
Measurement Over wires
TTCE
TCE
Lead
TIF
Major Diameter
Minor Diameter
fillet radii
It does not specify
Involute error
Pitch error
IF the diametral pitch & # of teeth in the AGMA 2000-A88 Standard, rquires Involute & Pitch error
and it is not specified in the Engineering drawing
Is it required?
yes or no
Please give your take on this.
Gear Tab Block
Gear Data Specifies
AGMA Q8
# Teeth
Diametral Pitch
Pressure Angle
TTCE
TCE
Lead
TIF
Major Diameter
Minor Diameter
fillet radii
It does not specify
Involute error
Pitch error
Is it required?
yes or no
