Perhaps this is a tricky question...
Does having a dirty air filter hurt the fuel economy of a modern gasoline-fueled car? (Obviously the parts stores would have you believe that it does)
If so, how exactly?
If it's inlet restriction, then would you say the effect is the same as modifying the throttle actuator such that the throttle opens slightly less for any given pedal input than it would otherwise have opened? If this is equivalent, would you expect to get better or worse fuel economy as a result of such a modification?
If so, how exactly?
