Does anyone know where I can find Air springs that have a thru hole (donut shape), can lift at least 500 lb. Dimension sizes around 10" OD, 6" ID (size can very)
I have tried contacting them a few times, and have talked to there local reps. The problem is they do not have a thru hole on these air springs. They mount by threads on the top and bottom. I need to run a 3/8-24 rod thru the center of the air springs. If you know of any other sources to check out, I would greatly appreciate it<br><br>Richard
You might try using a tire inner tube. These are made for small tires like on scooters.<br>Maybe you can find a size that will suit your needs.<br>The two sites below sell inner tubes.<br><br><A HREF="
