Bert13
Aerospace
- Oct 31, 2005
- 1
I know there is an all around symbol for welds is there a symbol that I can use to specify that a fillet follows a complex edge all around the part?
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
It appears the standard only recognizes the all around symbol for tolerance feature frames.All Around Symbol. The symbolic means of indicating a tolerance applies to surfaces all around the part is a circle located at the the junction of the leader from the feature control frame.
I'm not sure what they mean by function. A weld would seem to be a function. Would a chamfered edge also be a function? I think the width of a rectangular groove would probably not be a function, but instead a dimension of a feature. Generally, when I want to indicate "all around" in a dimension I type the words on the line below the dimension.the symbol used to indicate a tolerance or a function that is applied all around the part or the surface
