allowable pressure for piping
2ndchild
Petroleum
Aug 20, 2005
31
what are the design pressure requirements for piping components (given in clause 6 in the part 3 of the EN 13480 standard)?
how can we design the maximum allowable pressure?
is the allowable stress the design one?
The maximum allowable working pressure (known as MAWP) for piping as well as piping components could be assessed by calculating the pressure and using the selected wall thickness as input parameter in the wall thickness formula.
You calculate back to the pressure as unknown parameter.
From the selected wall thickness the corrosion allowance and mill tolerance should be deducted first.
From this formula could be concluded that the design stress is certainly one of the determining parameters.
Maximum design pressures for piping component specifications are most commonly determined by the process or as per the limits as per ASME B16.5.
Regards.
