Seems reasonable there could be two levels of coefficients of friction, particularly if you approach it from a statistical/structural reliability point of view. Also, bearing pressures are reported as both allowable and ultimate, so why not friction? There is no single friction value - it is based on empirical testing, so there is some statistical distribution (hopefully bell) associated with the results. The farther (left) from the mean you proceed, the reliability of the resistance (in this case friction) is akin to allowable/working stresses, and is thus paired with load effects (combinations) which complement the resistance's reliability.
So I would be careful about believing this statement, without doing some research. Certainly, you are working with a Geotech who feels comfortable providing both. Maybe you can pick his/her brain?
mathcadboy said:
There is no allowable and ultimate coefficient of friction.
mathcadboy - where does it say that there is not one, or that it is not good practice, etc. etc. ?
Smvk3: you might not have them, but don't forget any other load effects which act with the primary effect H. But, in general, I think your on the right page based on the info your geotech has provided,
I am curious now, because I have only ever been provided allowable coefficients. And that is super conservative when used with LRFD loads. :/
"It is imperative Cunth doesn't get his hands on those codes."
