Aluminium RHS rule of thumb?
MarioGr
AU
Are there any approximate rules of thumb that engineers here use for aluminium RHS members vs steel RHS members with regards to bending capacity?
IE a 150 x 100 x 5.0 RHS member has a bending capacity (phi)Msx of 44.00 kNm. Therefore a 150 x 100 x 5.0 aluminium member's capacity would be (insert rule of thumb value here) 25%(?) of the steel value. Approximately 11.0 kNm.
Only asking because I've been asked to rough in some member sizes on the back of an envelope for a fabricator for pricing purposes.
Thanks very much.
For the same section, the strength should be proportional to the yield strength ratio, but the deflection should be 3X and the weight should be 1/3.
The typical good substitute is a larger aluminum section to match the bending/deflection and reduce the weight over using steel so it will be a bit more than 1/3rd, but still a savings.
One thing to watch is that a lot of the aluminum materials have higher yield strengths due to cold-working or heat-treating, but then if you weld them, the strength right at the weld is much lower- so it varies a lot depending on your detailing.
