Amada Lasmac LC1212a2....
Jwoody44
Industrial
Apr 3, 2012
11
How do you change the the standard focal position? When M100 (laser mode on) comes up in the program, the focal point goes to .15 all the time, when most of my cutting i do is around .4-.6. Its very annoying and time consuming and in the operator manual, it says it can be adjusted in the parameter screen but does not list a number to adjust, does anyone know how this can be changed and how to do so, thank you!!
Is your material tech called before or after the M100?
Does it do this on every program? post a section of your code leading up to the M100 please.
O7779 ( S.S 12 GAUGE )
N100 G90 G92 X50. Y50.
N105 M102 (C-SS0.105)
N110 E3
N120 M100
Sorry, this work stuff has really been taking up my free time.
Two places to adjust focus on this machine. "base focus position" is set by pressing the left most key on the cutting conditions page "custom" then press the param. Its almost to the bottom.
Other place is on the custom page it self. Only the top line, E1, has any effect on the focus position. You can change the others if you want but they don't do anything.
haha i dont blame you we've been on 60+ hours a week here but thank you i was able to figure it out after your post and i was always wondering why if you use a different E code other than 1 it wouldnt change the focal point...
