an unknown error occurred during solutions
MichalM1985
I have problem witch analysis.
"an unknown error occurred during solutions"
Someone can help?
The solver file:
Solver Output
ANSYS Multiphysics
| W E L C O M E T O T H E A N S Y S P R O G R A M |
* ANSYS 13.0 LEGAL NOTICES *
* COPYRIGHT AND TRADEMARK INFORMATION *
* Copyright 2010 SAS IP, Inc. All rights reserved. *
* Unauthorized use, distribution or duplication is *
* prohibited. *
* See the ANSYS, Inc. online documentation or the ANSYS, Inc. *
* documentation CD for the complete Legal Notice. *
* DISCLAIMER NOTICE *
* THIS ANSYS SOFTWARE PRODUCT AND PROGRAM DOCUMENTATION *
* EMBODY TRADE SECRETS AND CONFIDENTIAL AND PROPRIETARY *
* INFORMATION OF ANSYS, INC., ITS SUBSIDIARIES, OR LICENSORS. *
* The software products and documentation are furnished by *
* ANSYS, Inc. or its subsidiaries under a software license *
* agreement that contains provisions concerning *
* non-disclosure, copying, length and nature of use, *
* compliance with exporting laws, warranties, disclaimers, *
* limitations of liability, and remedies, and other *
* provisions. The software products and documentation may be *
* used, disclosed, transferred, or copied only in accordance *
* with the terms and conditions of that software license *
* agreement. *
* ANSYS, Inc. and ANSYS Europe, Ltd. are UL registered *
* ISO 9001:2000 Companies. *
* U.S. GOVERNMENT RIGHTS *
* For U.S. Government users, except as specifically granted *
* by the ANSYS, Inc. software license agreement, the use, *
* duplication, or disclosure by the United States Government *
* is subject to restrictions stated in the ANSYS, Inc. *
* software license agreement and FAR 12.212 (for non-DOD *
* licenses). *
***** ANSYS COMMAND LINE ARGUMENTS *****
BATCH MODE REQUESTED (-b) = NOLIST
INPUT FILE COPY MODE (-c) = COPY
SINGLE CPU REQUESTED
START-UP FILE MODE = NOREAD
STOP FILE MODE = NOREAD
00000000 VERSION=INTEL NT RELEASE= 13.0 UP20101012
CURRENT JOBNAME=file 18:45:06 NOV 24, 2012 CP= 0.780
PARAMETER _DS_PROGRESS = 999.0000000
/INPUT FILE= ds.dat LINE= 0
DO NOT WRITE ELEMENT RESULTS INTO DATABASE
*GET _WALLSTRT FROM ACTI ITEM=TIME WALL VALUE= 18.7516667
TITLE=
aaa--Magnetostatic (A5)
--- Data in consistent MKS units.
MKS UNITS SPECIFIED FOR INTERNAL
LENGTH (l) = METER (M)
MASS (M) = KILOGRAM (KG)
TIME (t) = SECOND (SEC)
TEMPERATURE (T) = CELSIUS (C)
TOFFSET = 273.0
CHARGE (Q) = COULOMB
FORCE (f) = NEWTON (N) (KG-M/SEC2)
HEAT = JOULE (N-M)
PRESSURE = PASCAL (NEWTON/M**2)
ENERGY (W) = JOULE (N-M)
POWER (P) = WATT (N-M/SEC)
CURRENT (i) = AMPERE (COULOMBS/SEC)
CAPACITANCE (C) = FARAD
INDUCTANCE (L) = HENRY
MAGNETIC FLUX = WEBER
RESISTANCE (R) = OHM
ELECTRIC POTENTIAL = VOLT
INPUT UNITS ARE ALSO SET TO MKS
*****TRACK MONITOR LEVEL= -1
TRACK PRINT LEVEL = 0
TRACK SUMMARY LEVEL= 0
1
***** ANSYS - ENGINEERING ANALYSIS SYSTEM RELEASE 13.0 *****
ANSYS Multiphysics
00000000 VERSION=INTEL NT 18:45:06 NOV 24, 2012 CP= 1.030
***** ANSYS ANALYSIS DEFINITION (PREP7) *****
*********** Nodes for the whole assembly ***********
*********** Elements for Body 1 "Solid" ***********
*********** Elements for Body 2 "Solid" ***********
*********** Elements for Body 3 "Solid" ***********
*********** Send User Defined Coordinate System(s) ***********
*********** Set Reference Temperature ***********
*********** Send Materials ***********
*********** Create FluxPar ***********
***** ROUTINE COMPLETED ***** CP = 1.420
--- Number of total nodes = 61982
--- Number of contact elements = 0
--- Number of spring elements = 0
--- Number of solid elements = 13794
--- Number of total elements = 13794
*GET _WALLBSOL FROM ACTI ITEM=TIME WALL VALUE= 18.7519444
************************* SOLUTION ********************************
***** ANSYS SOLUTION ROUTINE *****
WRITE ALL ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
FOR ALL APPLICABLE ENTITIES
******************* SOLVE FOR LS 1 ****************
USE AUTOMATIC TIME STEPPING THIS LOAD STEP
USE 1 SUBSTEPS INITIALLY THIS LOAD STEP FOR ALL DEGREES OF FREEDOM
FOR AUTOMATIC TIME STEPPING:
USE 10 SUBSTEPS AS A MAXIMUM
USE 1 SUBSTEPS AS A MINIMUM
TIME= 1.0000
ERASE THE CURRENT DATABASE OUTPUT CONTROL TABLE.
WRITE ALL ITEMS TO THE DATABASE WITH A FREQUENCY OF NONE
CONVERGENCE ON CSG BASED ON THE NORM OF THE N-R LOAD
WITH A TOLERANCE OF 0.5000E-02 AND A MINIMUM REFERENCE VALUE OF 0.1000E-05
USING THE L2 NORM (CHECK THE SRSS VALUE)
*GET ANSINTER_ FROM ACTI ITEM=INT VALUE= 0.00000000
*IF ANSINTER_ ( = 0.00000 ) NE
0 ( = 0.00000 ) THEN
*ENDIF
***** ANSYS SOLVE COMMAND *****
*** TREE GAUGING FOR EDGE ELEMENTS ***
*** ERROR *** CP = 1.513 TIME= 18:45:07
*** GAUGE command aborted ***
NUMBER OF WARNING MESSAGES ENCOUNTERED= 0
NUMBER OF ERROR MESSAGES ENCOUNTERED= 1
***** PROBLEM TERMINATED BY INDICATED ERROR(S) OR BY END OF INPUT DATA *****
+--------------------- A N S Y S S T A T I S T I C S ------------------------+
Release: 13.0 UP20101012 Version: INTEL NT
Date Run: 11/24/2012 Time: 18:45
Windows Process ID: 4664
Number of cores: 1 (Shared Memory Parallel)
GPU Acceleration: Not Requested
Job Name: file
Working Directory: C:\Users\Misiek\Documents\ansys nowe\_ProjectScratch\Scr7515
Elapsed time spent pre-processing model (/PREP7) : 0.4 seconds
Elapsed time spent solution - preprocessing : 0.0 seconds
Elapsed time spent computing solution : 0.0 seconds
Elapsed time spent solution - postprocessing : 0.0 seconds
Elapsed time spent post-processing model (/POST1) : 0.0 seconds
+------------------ E N D A N S Y S S T A T I S T I C S -------------------+
| ANSYS RUN COMPLETED |
| Release 13.0 UP20101012 INTEL NT |
| Database Requested(-db) 256 MB Scratch Memory Requested 256 MB |
| Maximum Database Used 25 MB Maximum Scratch Memory Used 29 MB |
| CP Time (sec) = 1.591 Time = 18:45:07 |
| Elapsed Time (sec) = 4.000 Date = 11/24/2012 |
In order to do a magnetostatic analysis, you have to combine all of the bodies into one part. Go to Geometry, at the bottom of the left pane, expand the parts list, select all of the parts, right click and select "Form New Part". Then do an Update to sync the changes, go to Model, expand Geometry, and you should see just one Part, with all of the bodies listed underneath. Double-check everything and then re-run Solve.
