Analysis Input File Processor exited with an error. 1
Ajith Kurian Baby
53
I was trying to do a reciprocating sliding motion simulation in Abaqus using static, general mode. When I turned on ALE mesh, the system threw an error:
"Analysis Input File Processor exited with an error."
It seems to work fine when ALE was turned off. I was using pressure load and displacement boundary condition in periodic form.
I kindly request your help to solve this issue.
That's a generic error message. There should be more errors in the dat and msg files. Please search for them and paste them here. Or attach the dat and msg files.
So the actual error message is "Only enhanced hourglass is allowed for element ... instance ... in adaptive domain". Thus you should set Mesh --> Element Type --> Hourglass control: Enhanced
I was trying to use UMESH subroutine for wear simulation. I don't have much idea about it. It always shows compilation error. Can u help me to write UMESH sub routine. I am attaching my code
SUBROUTINE UMESHMOTION(UREF,ULOCAL,NODE,NNDOF,
* LNODETYPE,ALOCAL,NDIM,TIME,DTIME,PNEWDT,
* KSTEP,KINC,KMESHSWEEP,JMATYP,JGVBLOCK,LSMOOTH)
C
INCLUDE 'ABA_PARAM.INC'
C
DIMENSION ULOCAL(NDIM),JELEMLIST(*)
DIMENSION ALOCAL(NDIM,*),TIME(2)
DIMENSION JMATYP(*),JGVBLOCK(*)
CHARACTER*80 bottom
DIMENSION ARRAY(3)
DIMENSION VEL(6)
CPRESS=0.0D0
VELOCITY=0.0D0
if (NODE.EQ.8)then
ULOCAL(NDIM)=0
call GETVRN(NODE,'V',VEL,JRCD,JGVBLOCK,LTRN)
else
call GETPARTINFO(NODE,0,bottom,LOCNUM,JRCD)
call GETNODETOELEMCONN(NODE,NELEMS,JELEMLIST,JELEMTYPE,JRCD,
$ JGVBLOCK)
call GETVRMAVGATNODE(NODE,'CSTRESS',ARRAY,JRCD,JELEMLIST,NELEMS,
$ JMATYP,JGVBLOCK)
CPRESS = ARRAY(1)
VELOCITY = VEL(1)
WEARRATE=0.000035377*VELOCITY*CPRESS
ULOCAL(NDIM)=ULOCAL(NDIM)-WEARRATE
RETURN
END
