Animation in UNx3 1
kges
5
Hi!
I want to rotate my assembly. What feature allows animations if any. I want to drive a wheel over rollers and get them to turn. Can I export to Pro-Engineer which has more features.
Kevin
I disagree with your statment that Pro/E has more features. Even if it really does, usually the identical feature in UG works easier and is more reliable.
UG has a Scenario for Motion module that should allow you to do what you want.
"Fixed in the next release" should replace "Product First" as the PTC slogan.
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
I have seen the motion application but seems to be difficult to figure out. Can you please give me a few pointers as how it actually works. As I select a compoment then it tell me class but doesnt progress any further.
Kevin G.
1. Make sure Assemblies is enabled (Application > Assemblies, or Ctrl+Shift+W)
2. Use Reposition Component (Either go to Assemblies > Components > Reposition Component, or use the Reposition Component icon on the Assemblies toolbar... it's a box with two << >> looking things on a diagonal...)
3. If your part is properly contrained (see Assemblies > Components > Mate Component...) and it has only the rotational DOF left, then you can rotate it in assembly mode.
Did that help?
