Anodize Aluminum 6061 1
sarclee
105
Hi, may I ask if anodizing Al6061 would make it non-conductive too?
Thanks IRstuff.
Yeah. I am concerned it is thin and whether it can survive during vibration... it sounds like I need to get some experimental data?
Anodize is mainly a cosmetic treatment with a side effect of corrosion protection.
If you need electrical insulation then use an insulator.
Anodize is also a fatigue crack initiation source. It forms an irregular, rigid, oxide crystal on the surface of a soft metal. Good for abrasion resistance; not so good if the part flexes.
Thanks MinJulep and 3DDave!
@MintJulep, the part needs to be insulated is also structural part... wonder what other metal material can be used other than plastic?
This question begs 'a reason WHY' are You considering anodize of 6061... when conversion coatings may do the trick.
OH,BTW what temper 6061??? -T4 or -T6... and 'how thin'? Is it to be welded?
For electrical use exclusively in a very controlled environment?
Etc. The quality of our answers = quality of the question/parameters.
Regards, Wil Taylor
o Trust - But Verify!
Hi WKTaylor,
My bad. The temper is T6.No welded joint and all screw and nut in a space environment.
It sounds like You might be designing a micro/small-sat?
I love spaceflight/spacecraft/satellite design... even though my bread-n-butter has been MIL! Materials in space are at a whole different level than earth-bound aircraft.
The NASA LDEF experiment used anodized 6061-T? for experiment trays... so it got +5.5 years on-orbit exposure. Awhile back I got a copy of the following document that might be very useful.
LDEF Materials Results for Spacecraft Applications
There are others, related to real-world [out-of-this-world] findings... do some digging.
Regards, Wil Taylor
