JStructsteel
- Aug 22, 2002
- 1,438
I looked at the truss blocking thread some time ago, and it seems blocking or 'mini shear walls' are used when a heel is large (top chord to top plate distance). I have shown the plywood extend up at every other truss to a nailer between the top chord. Contractor is questioning it. The heel is about 21" tall. Would a better detail be just some diagonal 2x's from top chord to bottom chord, and let the truss connection take the shear? Its not a huge shear load.
The overhang is large, around 6'-10" so the load path is questionable, do I count on the soffit board to take shear back to the wall?
