Ansys contact problem!!
lgianluca
20
Dear friends,
I'm dealing with a spring sheet inserction on a tube.
I'm conducting a static structral analysis because i would understand the max stress on the spring element.
The simulation is a 2D sim. to let reduce the computing time.
The friction contact was regularly detected (see image attached).
My problem is that applimg a displacement on the spring i'm not able to see the spring deformation (see results images).
Please help me because i'm loosing mi life!!!!!
Thanks friends!!
Erik do you have a database where it possible have download material proprieties for Ansys. Matweb is not a free database and besides there isn?t any plastic behaviour material descriction.
thanks again
unfortunately I do not have anything like that.
Search the posts in the forums here on engtips, because it is likely that someone has asked that before.
Eric usually do you consider the material non-linear beahaviour or you adopt the linear curve? it's really hard find plastic curve and information for different materials.
To be honest, I am not doing much analysis these days. I develop/programme scripts (FEA), and provide/responsible for customer support for Strand7, so I do not carry out any analysis these days.
If you have an specific question about nonlinear properties of certain materials, you can post it as another question. I am sure people will have some good feedback (they cannot do it here though since this discussion has got very long :).
So add another post if you have any specific question about some material properties.
