Anti-Static System for AIFR
KVARM
15
Can we use 2 mm spring coil for Anti-static system for Aluminium Internal Floating Roof?
As per the API 650 Appendix-H multi-standard cable should be used for Anti-static system. Both having 0.2 ohms resistance.
Kindly confirm whether this 2 mm spring coil is acceptable or not?
