ROCHESTER
- Nov 2, 2002
- 33
I'm a mechanical engineer for a small Bio/Pharm manufacturing company. Over the last 10 years I've developed some designs to improve cost efficiency of the air handling systems. The next, much bigger, plant is being designed. I've reviewed tha A&E's proposed design and would like to respond with suggestions for energy savings. I'm not a HVAC specialist and I'm posting here hoping for comments from the professionals on my ideas in the following areas:
* Psychrometric control for modulating AHU's cooling/dehumidification temperature as a function of OA humidity load.
* Feed forward loop control to improve temperature tracking with variable AHU DAT(50-70F)
* Dehumidification of OA(make-up air)prior to mixing with RA. Eliminates sensible cooling of RA to dew-point for dehumidification.
* Locate Fan(s) outside the air stream to reduce cooling load of the system.
I'd appreciate any discussion and/or comments on these topics. I feel reluctant to present these ideas to the professional HVAC engineers given my limited experience and qualifications.
