API 650 Tanks MAWP is too low to utilize convention / emergency vents
richissa
30
The problem is that the MAWPs on API 650 Storage tanks are too low to be able to utilize conventional conservation/emergency vents.
It was suggested by the client to increase the allowable working pressure and lower the operating pressure of the flare/vapor combustor header.
Can anyone please advise how to approach this problem.
Thanks!
A review of Atmospheric Storage Tank conservation vents and emergency vents from tank appurtanance companys -- Shand & Jurs; Protectoseal to name 2 -- will show that they are available down to 1/2 ounce per square inch. A 3/16" thick steel roof weighs about 0.7 osi.
Are you dealing with existing tanks, or designing new tanks?
