CaracasEC
- Aug 18, 2011
- 196
Dear All,
Is it acceptable the pump to be shimmed during alignment? The situation is that during our final alignment, we have noticed that the motor needs to be lower more, to have the alignment tolerance. However, the motor has no shim already and that we need to shim the pump in order to have minimum 3 mm at the motor as per api 686? hoping for your field experiences.,...
