API vs. ANSI pumps 1
curve3104
33
I'm sure this has been addressed previously, but wanted to know if anyone could help me out quickly....
I'm working on a project for a gasoline/fuel oil terminal, where fuel is delivered to tanks via a pipeline and pumped from the tanks to tanker trucks for delivery. We are adding new tanks and pumps. Pumps are located within the emergency containment area, but should operate at ambient temperatures and no more than 100 psig.
API pumps are much more robust and handle higher temperatures and pressures. However, I have heard that for any hydrocarbon handling, no matter what the conditions, always use an API pump. Is this simply a CYA statement by engineers or is it actually worth the extra cost? My opinion is an ANSI pump will do the job. Any thoughts??
Being an engineer myself, I like to CMyA sometimes. But, in this case, I think it's a little extreme. I am hoping to get some opinions from others to confirm that, or learn something that will change my mind. I don't want our client paying 3-4 times the cost unless it is going to benefit them.
Also, I've worked previously in sales and you would be amazed at the marketing tactics to attract engineers to buy a product.
OK. But just remember its comparing apples to oranges and you usually get what you pay for... or don't.
For lo press, lo temp, non-critical services, non-hazardous substances, lo stress conditons, I don't see anything wrong with using ANSI pumps. For critical services, I wouldn't touch one with a 1/2 joint of pipe. With APIs, you know what you're going to get before you open the box.
See your company spec. As you note, some project or company specs simply require API for any and all hydrocarbon service.
BigInch[worm]-born in the trenches.
I have been involved in two truck loading rack projects in the past two years. On one, located at a marine terminal, ANSI pumps were used, worked well, delivery was great, customer pleased. On the other, which happend to be located on the refinery property, API pumps were used, cost a whole lot more, delivery was longer, pumps work great.
In my opinion, if you can go with ANSI pumps, do so. There is no compelling reason to go with API on such a simple application.
The low temp, low pressure conditions suggest an ANSI will do fine. I would look at the "ANSI plus" features including big bore boxes and improved l3/d4 shaft ratios. I believe the installed cost delta is greater than the 3x to 4x mentioned.
Both will do the job, so will a couple of bucket. It really comes down to the risk you wish to take, API are designed for hydrocarbon handling where as ANSI are designed for chemical process. Sure, API are a lot more expensive and it would be in your interests to assertain why this is so by looking carefully at the differences in design and then make an informed engineering decision in conjunction with a designer of hydrocarbon handling installations, your insurance underwriters and probably any local authority having juristiction over industrial installations.
Phitsanulok
Thailand
ANSI pumps are available in ductile iron, stainless steel and other alloys. They are not available in carbon steel. Hydrocarbons, especially gasoline, should not be handled in iron pumps. They will crack in the event of fire. API pumps are primarily available in carbon steel casings which can endure fire exposure without cracking. API pumps should be used for gasoline. It is a safety thing.
I agree with the safety aspect. It is traditional that refinerty operations use API pumps just because of that reason. However, a fueling terminal is not at high risk for fires. In most cases, the pump suction can be (and is most likely part of the operation) isolated by an automated control valve. If you had a fire, the fuel supply to the pump will be shut off. I could be speaking out of turn, but I don't believe I've ever heard of a fuel terminal catching fire...at least not on a scale to produce a catastrophic failure in equipment.
Perhaps you should look at the whole of life costs.
The purchase price represents a very small number in the life of a piece of plant. The API pump will prove more reliable and will be available for longer times ie reduced MTBF. Ths requiring fewer maintenance resources.
What is the cost of the plant not being available? Would one incident over shadow the perceived difference in cost?
As an engineer I start with the aim to provide the client with the best & safest technology available. Then I expend time and energy looking at lesser quality solutions to see if they can be justified. Project managers and procrement people tend t want to go straight for the cheapest solution and get me to justify their desires to keep costs at the lowest point. They rarely have the skills to engineer things or look at the overall costs.
Engineers go to jail for their mistakes project managers just miss out on their bonus.
Specify the API pumps. If the client wants a lesser pump then do his bidding providing that you make him or her fully aware of the risks or consequences. Make sure their is a HAZOP done and document the clients decision to go with the lesser pump.
Yes you need to CMYA for in today's world there is no where to hide from the judicary. They hold the view that if the technology exists to make the workplace safer it should be employed.
Geoffrey D Stone FIMechE C.Eng;FIEAust CP Eng
"ANSI pumps are available in ductile iron, stainless steel and other alloys. They are not available in carbon steel. Hydrocarbons, especially gasoline, should not be handled in iron pumps. They will crack in the event of fire. API pumps are primarily available in carbon steel casings which can endure fire exposure without cracking. API pumps should be used for gasoline. It is a safety thing."
ANSI pumps most certainly ARE available in carbon steel if you want them that way. From reputable pump manufacturers, at least.
The client did request ANSI, therefore it is our job to confirm that will be acceptable (which we have, and it is).
I have worked with many fuel terminals in the past. Most all not attached to a refinery have used ANSI pumps. One that did use API pumps that comes to mind was built when a company was flush with cash but they could not afford to overhaul the pumps 15 years later. Even a stainless steel pump that would not crack in a fire would be more cost effective than an API pump. Some safety upgrades like a disaster bushing on the seal gland can be purchased on an ANSI pump.
