I have a question regarding the use of appendix 2 flanges vs standard flanges
If the diameter of heat exchanger is such that standard flange of ASME B16.47, series A can be used, should you go for a standard body flange or a non standard flange??
Since, I have noticed that a standard ASME flange, if calculated as per the rules of appendix 2 fails.
Moreover, standard B16.47 Series A flange, if checked as per rules of appendix 2, require a higher thickness than a standard B16.47 series B flange
