AELLC
- Mar 4, 2011
- 1,339
See attached girder truss.
The psf loads in the lower right corner (TC LL=20 psf, TC DL=14 psf, etc,) are all proper and tidy - however, look at Special Loads in the upper left hand corner - where I have red arrows - and then look at the drawing, at the bottom chord on the right, where I have colored it red.
The majority of the dead and live load does exist on the roof deck, near the top chord, but the common trusses at 24" oc that impose the their loads to this girder apply it to the BOTTOM chord because that is where the truss hangers are.
Now doesn't that signify that these calculations are garbage, i.e., the web forces are in reality completely different, and the top and bottom chord forces are slightly off?
The design of the truss plates for web to chord is completely incorrect as a result?
Or am I completely not seeing that these calculations are indeed correct, because the truss plates H1315 and H1014 are relatively large?
These truss calculations, for some reason, do not identify each member and what axial force exists in it.
