Applying kinetic energy to a circular hollow section
30
Hi All,
I have some value of kinetic energy, 1.82 kN.m which I want to apply to a steel circular hollow section member Dia. 140mm x 10mm thickness, 5m length.
I want to apply this energy as a force. Is there a way I can apply this?
HD
What exactly is the intent? As written, your question doesn't make sense.
Force = m * dv/dt
KE = 1/2 * m * v^2
Force is therefore related to the rate of KE applied; you can apply it in a nanosecond, or in seconds.
TTFN (ta ta for now)
Assuming that by "as a force" you mean you want to impart the energy mechanically as opposed to heating it up with a torch, etc.
Drop a piano on it from a height of about a metre?
That sounds like some kind of a fender system?? And you are looking for the equivalent of the fender reaction? You will have to figure the pipe deflection mechanics to get a force-deflection graph. Then see how much the pipe has to deflect to absorb your energy and determine the resulting elastic/plastic reaction force at this deflection.
Thanks for all the answers. This KE is from a traveling object that will hit the steel circular section, with a energy of KE = 1/2 * m * v^2, which comes out to be around 1.82 kN.m.
You could have started with that; it would have saved a day. Nevertheless, you also need the velocity.
> Are you trying to do this IRL?
> What are the materials involved? - marshmallow traveling at 600 m/s will have different impact characteristics than lead, or steel, or depleted uranium. Material of pipe needs to be known
> Are you trying to determine puncture resistance?
Well that was agony. I assume we are now talking about a ship or whatever smacking into a pile or drill shaft.
Cheers
Greg Locock
You have provided very limited info. What is the position of cantilever ( vertical or horizontal ) ? What is the material of the travelling body and mass ? The energy 1.82 kN-m can be obtained with different mass and velocity combinations..the peak contact force depends on several factors...pls provide some clues to get answer.
