Applying pressure equation on pipe external surface
sotree
Aerospace
May 15, 2006
4
0
0
Greetings!
Need help for applying non-uniform pressure distribution on a pipe outer surface. It seems that I have to use the advanced load method in FEMAP 9.1, but I am not sure how to do it.
Pipe geometry:
A thin-walled pipe (Dia=4', thickness=1"). It is externally pressurized with non-uniform characteristic. and the pressure function is given. This solid pipe is made of rubber.
ST
I tried this function with equations, and it works for me, I tried aply pressure on horizontal pipe and It works, so maybe I can help you.
In the equation line put the equation for example 2*(!x-1000)
remember the symbol "!" before the coordinates. This X,y or z is used as the coordinate system chosed in the load menu.
When you back to the load menu, you have to put sth as the value of the pressure, I have just put 1 there.
If you have problems, just ask :)
