KurtSauer
- Dec 11, 2002
- 17
Anyone know why Autodesk in the 2013 program has decided to change the "ARRAY" command from an extension of the "COPY" command to the creation of a block (or some other single entity) instead of basically resulting in the very familiar multiple copies of a group of objects that we ( or at least, I )was used to seeing in 2011? (I never installed 2012, so maybe this occurred in that version.) Is there an easy "fix" to return to the classic version of the "ARRAY" command as the default (I know the system recognizes this because I ran across it in a "HELP" function, but I can't find a way to get to that point, and haven't had a reply yet from my inquiry to AutoDesk.) Thanks.
