AS3600 clsuse 6.3.2 (c) says to consider change in bending stiffness due to axial compression. The commentary refers to stability functions C and S and a book from the 1960s. Is this just p-delta between the ends?
AS3600 is also still written for software that can't do full p-delta analysis. It assumes that only the effect of joint displacement and not member deflection is included. The commentary actually refers to using a microcomputer it's that old. Anyway, subdividing the member fixes this even with the type of software the code is thinking of. Is it ok just to do full p-delta and skip moment magnification?
