silkwormfrog
- Apr 27, 2013
- 3
- 0
- 0
Hi
I have trying to calculate the fault level (ground fault) by using AS3851 method.
In section 8.5.2.1, the factor k for the R/X and X/R ratios can be obtained using
k = 1.02 + 0.98 * e ^(-3R/X).
I have been given the following:
the source 3 phase max. fault level 3800A
the source 3 phase max. fault level 3600A
the source 1 phase max. fault level 930A.
the source 1 phase max. fault level 910A
So for 3 phase fault, k = 0.746.
The problem is I cannot obtain R/X ratio using k = 1.02 + 0.98 * e ^(-3R/X) due to obvious reasons.
Is there anyway to get around this problem. Please note I need to follow AS3851 standard. Many thanks
