ASCE 7-16 wind load
theUnsubber
1
Good day.
First off, sorry if this question might come off as very basic as I have mostly worked with a different structural code.
My concern is regarding the definition of "L" in ASCE 7-16 Figure 27.3-7 (see attached). The notation guide below the diagram states that L is the "Horizontal dimension of roof, measured in the along-wind direction, ft (m)". This appears to be in contrary with the diagram wherein L is measured along the edge normal to the wind direction.
Can anyone with expertise in American codes clarify the definition of L? Thanks in advance.
It doesn't appear to show up in the ASCE errata found HERE
Is there a diagram with wind direction γ = 0°? It may clear the confusion.
This appears to be a typo in the graphic portion of Figure 27.3-7. To the best of my knowledge, the ASCE 7 approach is to consider 'B' to be perpendicular to the direction of wind and 'L' to be parallel to the direction of wind. I believe the written definition of 'L' is correct.
Case 1: Wind Direction at 0 degrees with L along-wind direction (sloped)
Case 2: Wind Direction at 90 degrees, where L is not used
It's an error, and I second Hokie's interpretation.
