1
- #1
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
I've never understood this objection. I used ASD89 for 3 years then LRFD since 98. I've designed many projects with very tight early release schedules with LRFD and it doesn't cause problems because I very rarely crank through sizeable equations from the Spec. It's either done with a program or a table. If someone's still doing lots of manual calcs in 2010, then IMO that's an issue with how the engineer chooses to do the calcs. If the issue is that the mean ole' 13th Ed. has a design check (that applies) that wasn't in the 89 Spec., then no sympathy on needing to check it, right?
The design is still left to your discretion but now you have "correct" equations to use whereas you previously did not for many design checks. The creation of LRFD or development of new equations has not taken the design away from engineers. It has taken it away if one would prefer to just cook up untested methods for a larger chunk of his work. We have to do this at times, but the fewer times the better, right?I think the other main argument that takes place is simplification. Some of the arguments above state "ASD 1989 did not incorporate various design checks"...you are absolutely right..it was left to the engineers discretion to verify and check the design.
In my experience, senior PEs and SEs do more manual calcs because their time is too valuable to sit there operating programs for days or weeks on end (and therefore, it's not worth it to learn the programs in detail). They'd do quick and simple stuff manually and have the junior guys crank for days or weeks with the programs. They'd never approve of the junior guys trying to design dozens of composite beams on their jobs manually, for example. The senior guy might use a Manual table for a composite beam or two at random, though.(SIDE NOTE: All of the Senior PE's I work with love that I do most calcs by hand. Maybe because it's much easier to check.)
