Asme Code Calculations
tc817
5
In regards to asme Code for pressure vessels, Does Asme code state or regulate about using calculations for someone else's design as my own?
More specifically, I am under a time crunch and have been going back and forth with our AI and engineering in regards to calculations for an obround flange, and I was thinking it would be OK to use someone else's calculations seeing as it going to be built exactly to the specifications of that design.
tc817 forum292 is probably a better place for anything other than the specific ASME drawing standards, Y14 series etc.
