hello all,
I have asked this question before (in other forums) and gotten a variety or responses, none satisfactory....
My question is about a new component in a process facility. I am not sure if it will require an ASME Code "stamp" and National Board Certification or not...
The "tank" (really a reactor)is 6 ft dia. 10 feet SS and operates at a maximum of 12 psig. However, it also has a half-pipe jacket that will operate at about 100 psig (400F).
The tank will have a modest vacuum of -10 inches WC....
The "tank" will be designed and constructed to ASME VIII - Section I.
My question is this: Does the jacket pressure/ temperature require this "tank" to be a stamped, ASME vessel ? If so, can someone point me to the chapter, verse, and/or code case that confirms this ???!!
MJC
MJC
