ASME piping code
pegus
Aerospace
Mar 18, 2015
67
Good day,
I am currently looking to take a course into ASME piping design. In your experience, what piping design course do you recommend me to take?
I will be working with pipe lines transporting dry air at hot temperatures, so I am interested in learning:
-Considerations for supports. (fix supports, axial guides, hangers, etc.)
-Material and thickness selection.
-Flexible components selection. (expansion joints, flex hoses, etc).
-Structural validation, ensure the whole pipe line from fix point to fix point will withstand the design conditions.
-Best practices.
I am mentioning ASME because the work will be for US, more specifically a testing laboratory.
Thanks in advance,
P.P.
Hot air in testing lab at what pressures and temperatures? Most likely B31.3, but that depends upon P&T.
Thanks for the reply pmover,
The Pressure ranges will be from 0-350 psig.
Temperatures from -20F to 1500F.
P.P.
