1
- #1
engineermat
I need your advice of the ASME VIII DIV.1 regarding the following two issues:
(1) The distance of the circumferential weld seam and nozzle reinforced pad is only 1 inch (Circumferential joint to the fillet joint of the re-pad).
(2) The circumferential weld seam is covered by the reinforced pad. The distance of the circumferential weld joint and the “nozzle to shell joint” is about 1 inch.
What is the code requirement on the above two situations?
Thanks.
Thanks.
