nx6loader
- Oct 12, 2009
- 7
im having a problem with assembly drawings. i have assembled a mould where i created cavity and core with subtracting product through linking it to plates.
product outer edge was created with revolved command. i have revolved studio spline with a 1mm offset to get the product as showed in "product" image. in the product drawing it shows all edges correctly.
but in assembly drawings as in "assm drawing" image.. outer edge is upset. some times when i update the drawing it automatically corrects itself. but then when close and reopen it.. its upset again.
i have tried loading product manually before opening the assm. and unselecting load assemblies partially option. nothing worked. im using NX6.
pls need help on this.
all the other curves are displayed correctly.only this edge has the problem.randomly it correct itself sometimes.
