Assign attributes to many parts
Martin898989
14
Hi guys,
I have a huge assembly. I want them all to have some attributes like: Name in German, Name in English, Size.
My assembly looking kinda like this:
- Assembly 0
- Assembly 1
- Part 1
- Part 2
- Assembly 2
- Assembly 3
- Part 3
- Part 4
- Assembly 4
- Part 5
- Part 6
and so on...
Thank you very much
Martin
you should have a look at "attribute templates"
This should , if I understood it correctly , provide you all the attributes in all your files.
Tomas
The more you know about a subject, the more you know how little you know about that subject.
I have to come back... When I close my assembly where i have set up the template its gone after opening again... :(
BR
Martin
I have created an attribute template:
Attributes:
- Name DE
- Name EN
- Info
- Material
Somehow NX is creating out of 'Material' a NX attribute: NX_Material..
Someone knows how to prevent NX to create this NX_Material
The NX_Material is locked and i cant change it... :(
Thank you
Martin
Under customer defaults > Gateway > materials/mass / Part attributes
Uncheck the create part attribute.
Gelson Z. Nicoletto
V.18-NX1980
i have used a self created template. But now I cant change the attribute.
Please see my video:
And as you can see in the screenshot i cant tick the green check button..
I hope someone can help.
Thank you
Martin
The default setting when you install NX is that the option that Gelsonnicoletto mentioned :
"Under customer defaults > Gateway > materials/mass - Part attributes", is set.
This will , when you assign a material using the NX material library , also create the attribute with the name that can be set under the same customer defaults.
Once set, this attribute can ONLY be changed from the Assign Materials dialog-s because it is linked both to the material which is applied/assigned to the solid body and also the material table.
It is not "just a simple attribute" because of these links.
If you want an "attribute only" which is not associated to the specific body, nor connected to material properties, you probably need to name this attribute "My_material" or something similar, or you change the customer defaults to use a different name.
Tomas
Okay, got it. I had to restart NX. Now I can change my self created Material attribute.
Thank you all very much
